Squeaky 650
Old Jul 19, 2005 | 12:06 PM
Squire's Avatar
Default Squeaky 650
When I push down on the bars of my 650, it creaks and groans and squeaks. I have tried spraying WD 40 form the can up into the struts/shocks but to no avail. Suggestions appreciated...Thanks!
Old Jul 19, 2005 | 05:50 PM
tuffEnuf's Avatar
Default Squeaky 650
Culprit is probably A-Arm bushings. Some Forum members have drilled and tapped A-Arm/bushing for Grease fitting.
Old Jul 19, 2005 | 07:18 PM
Exrider22's Avatar
Default Squeaky 650
drilling grease fittings is a great idea, i hope one day to do it. The best fix for now though is to go to home depot, or really anyplace like it, and by lithium grease. put it on the bushings and it will work great. my kfx 400 was sqeaking if you look at it funny, now its good as new. Try not to use wd40 cuz i hear it eats youyr bushings, not postitve though just what i hear.
Old Jul 20, 2005 | 01:05 AM
mastrblastr's Avatar
Default Squeaky 650
You can also make the a-arm bolts greasable. You need a lathe (or a machinist) to get it done. Starting at the bolt head end of the bolt, drill a 1/8" hole down the center of the bolt about half the length of the bolt. Drill a 1/8" hole through the diameter of the bolt that intersects the hole you drilled through the length of the bolt. Drill the 1/8" hole in the bolt head out to 9/32" about 1/4" long and tap it out to 1/4"N.C. thread. Screw in a grease zerk and put the bolt back in the a-arm. Before you crank it tight, lock a greasegun on the zerk and give it a couple pumps. Tighten the bolts to spec and all will be well!!
Bayou185rocks
Apr 6, 2009 04:57 PM
Juggernaught
May 9, 2007 05:22 PM
maxdad
Nov 9, 2006 08:04 AM
tack
Mar 24, 2004 06:40 PM
TyreSpinner
Jun 18, 2003 02:24 AM
