03 KAW 360 4X4....OIL LIGHT
Old Jul 21, 2005 | 07:53 AM
Jeff1216's Avatar
Default 03 KAW 360 4X4....OIL LIGHT
After a little riding my oil overheat light keeps comming on.... What problems do I need to look for??
Thanks in advance
Jeff
Old Jul 21, 2005 | 01:34 PM
alwaysride's Avatar
This happend to me last year. The oil light came on during a ride so i let i cool off. I made my way back to the cabin. I knew the fan wasnt working so i shook some wires just trying to see if i could find anything and went back out for a bit. The fan started workin again. You should make sure the fan is opperating correctly and if not, check all the wires and fuses.
Old Jul 22, 2005 | 08:53 PM
Japtrap's Avatar
Hi Jeff,
I use to own a Prairie 360 and I experienced the same problem. As it turns out, the cure for my bike was the wires attached to each side of the bottom of the oil cooler....they were completely clogged with mud. I removed each wire, one at a time, cleaned them thorougly and coated them with dialectic grease before reconnecting them. This solved the problem for me. I hope this helps.
Bracken
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
