Bayou 185- stuck intake valve
Hi,
I just got a Bayou 185 for $210, in non running condition. It is a little beat up, but it was running and driving a year ago. It has been unused for about a year now, since the previous owner moved and had it in a shed. It did not seem to have much compression, and it sounded like air was coming out the carb. At home I was watching inside the cylinder with a flashlight and pulling the rope slowly, and noticed I could only pull it out so far. I took the covers off the valves, and noticed the intake valve was stuck. I can only get it to come back a small amount. The previous owner did work on it a little this year, but gave up. Could the valve be bent? How much damage could that do to the piston? Does anyone know where I could get a new or used intake valve? If it werent for that, it would drive. Thanks in advance.
Well, I can pry it up about 1/4" with a screwdriver on the top of the spring, and can't get it any farther. I called 2 dealerships and they both said I need to take the head off, but a new head gasket is $26, and the valve timing would be all messed up.
