Lakota question
Old Jul 29, 2005 | 07:58 PM
Offroader22's Avatar
Default Lakota question
I have a 01 lakota sport. The battery was replaced about 3 months ago. When i try to crank it with the e-start all i hear is a loud buzz. The battery wont start it and it wont hold a charge. I jumped it off a car and it ran for about 2 hours and then it just went dead after i stopped for 10 minutes. I used the pull start and it stayed for an hour then when dead when i stoped again a big mudpit cause i was stuck.i went to pull again but it wouldnt start (i think i was out of gas cause i didnt have a full tank when i started) but my real qustion is whats up with the battery after about a week it wounldnt crank anymore with a new battery.sorry for such a long post i just wanted every detail i could put in so i get the right answer. Thanks for answers in advance.
Old Jul 31, 2005 | 12:19 AM
bump
Old Aug 1, 2005 | 11:37 AM
tuffEnuf's Avatar
Make sure all your connections are tight and none of your fuses are blown. Sounds like your chargin system/rectifier not working or loose wire & not recharging your battery. Dealer might can check out rectifier for you. Also, posibility you got a bad battery/dead cell. Have your battery load tested at autozone.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
