CVT Trouble
Old Aug 15, 2005 | 11:50 AM
MTR360's Avatar
Default CVT Trouble
Well I moved up from the 360 to the 700 and I love the extra power. I put on 26' mudlites and DG 5 this week. Took it for a test ride around the subdivison and all was well. Loaded it up to go to the trails sat. Put about 10 miles of flat trails on it then went up a hill. I heard it start to squeal and the belt started to slip. So i started to head back to the truck with it slipping. pulled the CVT cover and found a BUNCH of oil. where could have come from? The dip stick says its full, not over full thou. It was a dark. Any ideas???
thanks
Old Aug 16, 2005 | 01:20 AM
alwaysride's Avatar
Default CVT Trouble
were you using low gear. Im not sure where that oil could have been coming from. Hmm. maybe somone with more knowlage can help. To be honest, i just wanted to bump this post because you need help. haha. good luck.
Old Aug 16, 2005 | 11:03 PM
bushpusher's Avatar
Default CVT Trouble
sounds like you have a crankshaft seal gone. take to dealer or get a new seal,pull clutch and install
Old Aug 18, 2005 | 03:04 AM
WVHillbillyWTF's Avatar
Default CVT Trouble
There are three seals behind there, really 2 seals and a plug with an o-ring. Could be any of them.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
caveeagle
Sep 19, 2015 01:20 PM
