Jetting Question V2 650
Old Oct 7, 2005 | 01:26 PM
Theshonk's Avatar
Default Jetting Question V2 650
I jetted my 650 (110) for 6,000 to 10,000ft I am back from my trip. I ride at 2,000 to 6,000ft what are the issues if I don’t change back to 122
Thanks
Shonk
Old Oct 7, 2005 | 01:44 PM
FASTFATBOY's Avatar
If you dropped the jetting chances are it will run lean. When you run lean your motor will build more heat and will not perform as well as it could. I don't think it will happen to you but you can melt or burn a hole in the pistons if you are extremely lean. My advice would be to rejet but if you don't want to then just keep an eye on the temperature and don't let you motor overheat. Also the jetting on the kawasaki's is different for the front and rear carbs, I don't know about the arctic cats but I saw on your post where it said you went from 122 to 110 was this for both carbs? With a jump of 12 leaner on both carbs you will probably really need to rejet.
Old Oct 7, 2005 | 05:42 PM
sammydogs64's Avatar
What is this an Arctic Cat 650? I guess that due to the AC leaner jetting from the factory. Go back to the 122 all around and buy a new performance snorkel (my buddie did) it really woke up his machine. Put the big snorkel on when you go high and leave the jetting alone.
Old Oct 8, 2005 | 10:31 AM
Theshonk's Avatar
Yes it's an AC 650 V2. I pulled the plugs and went back to the factory 122s. Is 122 jets Kawasaki 's standard? I'm going to the OR. Coast next weekend so I'll be at sea level. I may try splitting the difference when I get back.
Any thoughts
Thanks
Shonk
Old Oct 8, 2005 | 10:46 AM
Factory kawi jets are 138 Fr 142 R but I have installed some mods so I am running 142 145
Old Oct 9, 2005 | 10:28 AM
Theshonk's Avatar
Sammydog,
Any idea why AC would lean out to 122 jets and why they would not run different sizes for front and back? Also what snorkel kit would you suggest?
Thanks for the feedback,
Shonk
Old Oct 9, 2005 | 03:16 PM
AC have a very restrictive intake snorkel tube and the old style (2002) kawasaki air filter.
I believe K&N is making a less restrictive filter now and if you get a new intake snorkel it will really help. My buddie is running 142 F and R on his 2004 AC 650, his plugs look perfect..
Go to ARCTICCHAT.COM plenty of ideas
Cole Hadden
Jun 15, 2025 09:05 AM
MIKEYTRXSHEEBANGS
Dunes and Dune Machines
Aug 27, 2015 12:57 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
