Glowing red rear cyl. tail pipe
Old Oct 11, 2005 | 11:27 PM
blawhorn's Avatar
Default Glowing red rear cyl. tail pipe
I was out tonight and noticed the rear tail pipe was glowing red. Took the jets out and noticed the front is a 152 and rear is 158, is this bigger than stock?
What are you guys running?
Old Oct 12, 2005 | 03:10 AM
Doctorturbo's Avatar
GOT BOOST!
On what quad? A V?
Old Oct 12, 2005 | 06:58 PM
Degs's Avatar
Do you have the Icm computer in your Kawi? I put the ICM on my 750 Brute and it changes the timing, making it run much more hot then stock. Header pipes do glow now
Old Oct 14, 2005 | 09:21 PM
blawhorn's Avatar
Sorry guys, BF 750, and it is completely stock.
I cant figure it out, why it would do it with such a big jet?
Old Oct 15, 2005 | 12:26 AM
Sparky8370's Avatar
They run the rear cylinder a little fatter because it gets hotter. Not as much airflow across it, and the air is already heated from the front cylinder. Just like on triple 2 strokes, they run the middle a little fatter. (Refering to the jet sizes here.)
Old Oct 15, 2005 | 12:29 AM
Sparky8370's Avatar
Oh yea, check for air leaks between the carb and rear cylinder. Sounds like your running lean. Make sure your rear carb doesn't have any $hit stuck in it.
Old Oct 15, 2005 | 09:33 AM
Degs's Avatar
If you have taken your carbs off check your carb boots. I had mine jetted, and the boots got ripped when they put them back on. Whenever i hit water it would cut out and we finally found out what it was. They have had a few of them do that so if you have messed with teh carbs at all check the boots, that might be your lean mixure.
Old Oct 15, 2005 | 11:39 AM
blawhorn's Avatar
I pulled the carbs apart and cleaned them real good, checked the boots, no tears. It sounds like it is just running lean because of the jetting, but why with such a big jet?
Old Oct 15, 2005 | 01:58 PM
Sparky8370's Avatar
See my first reply for the short, simple answer to that one.
Old Oct 15, 2005 | 05:56 PM
GOT BOOST!
Wow, This is a real mystery. Your jet spread is about right too. Might double check the boot again. Other than that I have no idea. Let us know what you find.
