For engine geniuses please help!!!!!!!!
Old Dec 13, 2005 | 11:20 PM
scottwvu's Avatar
Default For engine geniuses please help!!!!!!!!
Have a 2000 Lakota 300....Rebuilt the engine.....put it back together, and it ran fine.
However the left rear side transmission cover was leaking oil...so I re-sealed the cover and I now have no fire. The engine will turn over but will not hit.
Have checked the pick-up coil, the stator and the neutural start switch and all check out fine.
So my question is what the h.ell.....
Old Dec 14, 2005 | 12:09 AM
Daniel631's Avatar
Here is a really silly question. Is the engine stop switch in the "run" position?????
Old Dec 14, 2005 | 12:18 AM
scottwvu's Avatar
yes the motor willnot turn over if it is not on
Old Dec 14, 2005 | 01:12 AM
Daniel631's Avatar
Some will turn over but not have spark with the switch in the off position. Did you check for spark with a new plug??
Check the ground connection on the ignition coil. Unplug the cdi and hot wire from the ignition coil. Check the hot wire for continuity to ground> There should be none.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
Big bousse
Sep 26, 2015 10:42 AM
austinwhitton
Aug 11, 2015 06:21 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
