BF 650 and NO wheelie??
Originally posted by: DRIZZLE
That makes sence TeamgrnMojave. Do you think if I put the blue primary in if it would respond quicker and let me wheelie?
My dad has a bone stock Twin Peaks 700. The only thing that has been done to it is 26" Mud Lites, and C-Series wheels. Anyhow, it will stand straight up if you want it to. I would say something is wrong if it wont wheelie.
#15
Minejumps up with 30 inch mud-lites. I am getting a little sqeak from the belt in high but she will still flip you over back words if you arent careful. Burning the tires means you got the power. I would say Mudbugs are not great on the street.
#16
On my 02 p650 with 26 " mudsharks on , red spring, HL module, K&N filter and moose jet kit, my own mufler mod.. I couldnt keep the front end from comming up.I had to take the red spring out to make it more manageable.I also had my rear shock set stiff .
#17
I may try to do another map on the copperhead to get a faster throttle during the hole shot. I would put the stockers back on but I am using the factory rim wth the bugs. The are not very good on asfault but I didnt buy them to perform there : ).
#18
I bought a '07 650D this spring. I tried a few times and I could get the front wheels off the ground, maybe 6 inches, if I had someone on the back. I took it on for a 10 hour service and it seems to less power. At least for wheelies anyway. I put on some Titan 959's and it roosters but I tried and tried in low, high and no wheelie. Top end is 100 kmh( 63 mph ) Can I have a bad belt already? I have under 20 hours.
#19
Wheelies come from within grasshopper. Try doing them from a bit of a roll, stab it and then just balance from there. You can wheelie a stock Prairie with any tires, it's all in your initial stab of the gas and then your commitment to the balance.
