single or dual outlet exhaust for a kfx 700?
#15
I love my MUZZY setup, It sounds unbelievable and opens the V up. I beat a 450R and Predator
a few weeks ago but not by much. I need to get the spring setup next. LOVE that Angry 4-stroke!!
#16
As a rule of thumb, a two into one exhaust (MUZZY) will give you more low to mid-range torque. The true duel exhaust will move the torque up higher. Just depends on what you want to do.
#17
just bought a stock v force 700 i am intersted in this spring what is it and what does it do also were is it so if i decide to change it i will know where it is. also do i need to change any other parts to work with spring, air filter, exhaust etc....
#18
I got mine two weeks ago. I went with the epi pink and i also got a maroon but have not put it in. go to www.700v.com and see the instruction part on the left side of the page, their is pictures and directions. it is an easy job.
#19
Dont forget about the white bros carbon pro, retails for $800 titanium pipes, carbon fiber muffler. Alot of closeouts on ebay. You can get them for $300 ish. Sound Badass and have(dyno proven) stronger mid range than muzzy but not as good on the bottom. Best price too. System weights 5-6lbs max.
#20
