check belt light keeps flashing
Old Jan 18, 2006 | 10:10 AM
madmuddin1's Avatar
Default check belt light keeps flashing
How do I reset the check belt light on my 2003 prairie 360 4x4? My 4 wheeler has been running fine but the light stays flashing.
Old Jan 18, 2006 | 10:28 AM
sandpit's Avatar
How many miles are on it.You may need to replace the belt.
This happened to my old one at 1000 km.I just had to reset it.This is a copy of what I got to do it...
"1. Turn the ignition switch OFF.
2. Disconnect the belt failure switch at the 2-pin connector above the CVT cover. (Note: Just follow the wires coming from the rectangular black box on the CVT Cover to locate this connector.)
3. Disconnect both sets of 5 pin connectors located above the CVT cover. one is black and one is grey.
4. Connect these 5 pin connectors to their opposite pairs (grey to black and black to grey).
5. Turn the ignition switch ON.
6. Observe the belt-warning lamp. It should be flashing at a 0.4 second interval for a few seconds then start to flash slower. Let the lamp flash for at least seven seconds.
7. After seven seconds or more, turn the ignition switch off.
8. Reconnect 5 pin connectors to their proper location (black to black, grey to grey).
9. Connect the belt failure switch 2-pin connector (wires from CVT cover).
10. Turn the ignition switch on to confirm that the belt warning light is not flashing. Retry this procedure if needed."
Old Jan 18, 2006 | 12:20 PM
Hayashi's Avatar
If the flashing lamp does not shut off even after trying that cancelling procedure 2 or 3 times AND the machine is running normally, you need to replace the belt light indicator assy. It has reached the end of its life span.
Old Jan 19, 2006 | 09:12 AM
madmuddin1's Avatar
Thanks, I haven't tried it yet but I will take your advise before the weekend. Hope I can help you some day. Charles
bzdok1234
30
Feb 23, 2016 01:55 PM
ltrmc02
Jul 22, 2015 04:50 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
