need help with mojave timing
the flywheel don't have to come off to change the timing, you can do it with the cams. The exhuast cams dot must has to be pointing to the front and level with the top of the head, while the intake dot has to be pointing to the back, but up a half tooth from the top of the head....motor MUST be at TDC to set the timing
Mojave250A
Jul 11, 2015 10:38 AM
