Brute upgrades?
Old Feb 19, 2006 | 05:33 PM
killzoneq2's Avatar
Default Brute upgrades?
Note to self...........always listen to my dealer!!!
Old Feb 20, 2006 | 01:54 AM
Curls's Avatar
Stormseeker,
I went with the VDI Copperhead CDI over the Dyna CDI. They both do close to the same thing and both are plug and play, no splicing or cutting wires. The difference is the Copperhead from VDI has the ability to hold and run two maps. One can be set for 87 octane and the other can be set for 91. Or you can set one map for lower elevations and have another map that will work a little better at higher elevations. The Copperhead also has leads which you can use for various things, one of which can be used for a tachometer. The Dyna CDI can only hold one map with no ability to adjust anything. The Dyna also had really bad failures in the initial production runs. I have heard the quality issues are better, but with electronics I am always a little leary until I see a good quality track record established.
Old Feb 20, 2006 | 12:01 PM
stormseeker's Avatar
you know the copper head has good advantage with two maps and tach wire. I read the new dyna also overrides the belt lite for full power, does the copper head do that as well ??? if so that would be the module to use, also it is less expensive , sounds like it is good unit.
Old Feb 20, 2006 | 03:03 PM
Curls's Avatar
With the VDI you can select what you want to turn on or off. You might want the reverse overide disabled, but leave the belt switch enabled. You can mix and match everything or nothing it's really easy to use.
Old Feb 21, 2006 | 11:22 AM
  #15
Curls,
thanks for the info I think I will get the copperhead instead of the other, it costs 2\3 less
what do you think about the hot cams ? I dont really need more power than 10 extra hp.
but I like a quiet atv also so a pipe is not an option
Old Feb 21, 2006 | 03:41 PM
  #16
ToughGUY2169's Avatar
I will still get the dyna. When copperhead's unit has been out for a while I will think about it.
Pgbama11
Jan 16, 2016 08:19 AM
ylomnstr
Sep 22, 2015 12:19 AM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
Pgbama11
Sep 10, 2015 08:20 AM
ylomnstr
Sep 4, 2015 05:02 PM
