What spring for the 750??
Old Feb 2, 2006 | 05:07 PM
hollowcd's Avatar
Default What spring for the 750??
I have been reading some posts on changing the primary spring on the Brute 750's. It seems to be a cheap and effective modification, which is what I am all about. What do you guys suggest? I have a VDI and the dynojet kit, and other than that and the twin air filter I am all stock. Thanks in advance.
hollow
Old Feb 2, 2006 | 08:24 PM
STAKK's Avatar
I have a EPI Maroon in mine, but I have a pipe and 26 inch Mudlite XTR's....if you don't have a pipe and are running stock or fairly light tires, the EPI pink will most likely be best....
Old Feb 2, 2006 | 11:04 PM
cammoman's Avatar
I agree with STAKK. I tried the almond secondary, and then the black secondary with the maroon primary, but ended up taking out the black secondary and going back to the stock spring. The maroon primary works good with the 26" tires. If your running 27" or larger I would also go with a secondary spring.
Old Feb 3, 2006 | 01:23 PM
FASTFATBOY's Avatar
Try checking out nyrocs web site. They did a test on primary springs in the past. There is alot of info there and it may help you with your decision.
shimanok2
Jan 29, 2016 07:37 PM
brinkkl2000
Oct 16, 2015 11:08 AM
chuck1177
Aug 11, 2015 03:22 PM
Wnthunting
Jul 9, 2015 03:02 PM
Mphillips
Jul 2, 2015 07:20 PM
