Mojave Kick starter
Old Apr 5, 2006 | 09:58 PM
MudSlinginMojave's Avatar
Default Mojave Kick starter
Welp, if I have to pop off that cover, I'm gonna have to do it tomorrow with daylight after school [img]i/expressions/face-icon-small-sad.gif[/img] How hard is it to get that cover off?
Old Apr 5, 2006 | 10:01 PM
holeshotz8436's Avatar
first time it should take around 15 minutes and you might need to take the foot peg off....just pay real close attention as to how everything goes together........
Old Apr 5, 2006 | 10:07 PM
I have a Clymer Manual for it...When I pop that sucker off, are parts and bits going to be flying everywhere?
Old Apr 5, 2006 | 11:05 PM
rolsmojave3's Avatar
hello...your gears are probley bad, there will be a spring that will probley be a pain to winde back up, but it's fairly easy....just like holeshotz said drain the oil and what not
Old Apr 5, 2006 | 11:35 PM
  #15
When I pop off the clutch plate...are a bunch of pieces going to be flying everywhere and such?
Old Apr 5, 2006 | 11:37 PM
  #16
No...just pull it off slow and go easy on the cover and you'll be fine
Old Apr 6, 2006 | 08:09 PM
  #17
Ok well...I took off the cover and inspected the spring on the kickstart, seemed fine, but then looked at the gears. They were pretty chewed up, so I replaced them, and put everything back together. Now the next problem... [img]i/expressions/face-icon-small-mad.gif[/img] When I go to push the kickstart down it doesn't budge....And I'm pretty sure it has to do with the clutch, cause before we took it apart, the clutch plates were tight, and the cable was too...But when we went to put it back together, the plates were loose and so was the clutch cable. So I'm thinking it has something to do with that??? PLEASE HELP!
Old Apr 6, 2006 | 08:28 PM
  #18
what do you mean the plates were "tight" and "loose"
Old Apr 6, 2006 | 08:45 PM
  #19
You know how they're in that clutch plate holder like thing? Well before I took the clutch assembly out of the motor, they wouldn't move freely..basically stuck in position. Now, after I took them out and put them back in, they moved freely around from side to side(basically able to wiggle them around). And now saying that, I kept all the parts together so I wouldn't lose anything, how could they possibly be tight before I remove them and become loose after I put them back in???? Ideas???
Old Apr 6, 2006 | 09:09 PM
  #20
to make them loose you more then likley missed a plate, or didn't have the last steel plate lined up correctly and the hub didn't go all the way on...hope this helps
