HOW DO I MAKE THE KFX700 MORE STABLE AT HIGH SPEEDS
Has anyone got suggestions on how to improve the overall stability of the KFX 700 at high speeds. I have got aftermarket shocks but that doesnt solve the problem. I have read that it is a easy problem to fix but no further information was given. Maybe wider A arms or spacers?
How high of a speed are you talking about?
I would start with looking into how well your shocks are set up (Both front and rear) to work together and with the stock suspension etc. because investing in aftermarket shocks should have addressed the problem.
What type of complaint do you have with the stability? Is it darting around left to right, or just oversteering from any input from the bars or even back thru them from bumps in the road etc?
It could be something as simple as toe settings too so dont over look the easy stuff.
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Resident Killer!
on
I dunno I've ridden my Father's KFX700 wide open and I never felt anything unstable. It's too heavy to be unstable. My KFX400 is a lot scarier at top speed than the 700 seemed to be. The 400 is so light that it sort of floats along at top speed while the 700 seemed solid and easy to control.
I agree with the others that something must be off on your machine. Make sure all the front end components are tight, tires are all at proper PSI, and your not pushing too much toe-in or toe-out. Check for bent rims or loose wheel bearings too.
Something is fubard on your V. My V is very stable at any speed.
Like others have said, check the air pressure, wheel bearings, and rim run-out.
If all of these things are ok then you need to check the frame and A arms for bends. Toe won't make a vehicle feel unstable. Castor will make a vehicle a white knuckle ride. If all else fails you will have to put a castor/camber gauge on it and see if your quad is on spec.
