proper jets for dynojet kit with K&N
Old Jul 5, 2006 | 09:28 AM
ColdKaw's Avatar
Default proper jets for dynojet kit with K&N
Hi Guys, does anyone know what are the right jets for a KVF360 with a K&N filter and dynojet kit?
It ran great with the stock filter, but with the K&N it's too lean. The dynojet kit didn't say which jets were for the K&N?
Thanks
Old Jul 5, 2006 | 04:53 PM
mojo21's Avatar
I would say try the next jet size up in the kit. The dynojet kits come with 4 main jets i think so just look for a bigger jet... usually the kits tell you in most cases to run the biggest jet size in the kit if you are running a pipe and filter, if thats the case you wont be able to go to a bigger main. Try moving the clip on the needle down. Take little steps untill you find the rite air/gas combination. Do plug chops also. Im not a pro at this so if i explained something wrong some one jump in as well.
kenny
Old Jul 6, 2006 | 09:57 AM
ColdKaw's Avatar
Thanks Mojo, what are you looking for with the "plug chops" ?
The guys at dynojet don't recommend anything different with the K&N than with the stock filter. But to me it sure feels like it's running lean (very hot suddenly, popping when I let off the throttle).
Old Jul 6, 2006 | 02:42 PM
MadLT's Avatar
It sounds like you have leaned it out just a little. With only one cylinder the carb should be fairly accessible and easy to experiment with. Try one and two sizes bigger and see how it runs.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
