thanks bruteforce bob
Old Jul 20, 2006 | 11:59 AM
bruteforcebob's Avatar
Default thanks bruteforce bob
rammy, it is right next to your airbox snorkel close to the bottom its screwed to the bottom of the airbox. just take it completely out and extend your lines to your pod.I'll try to find a pic for you.
Old Jul 20, 2006 | 03:49 PM
Wildcountry's Avatar
Brute force bob I see that you have EPI Black secondary EPI Pink Primary I do you like this setup I was told that the epi maroon primary was also a nice setup I have a stock motor bu t do have twin air and also a vdi on the way what do you thin I should go with as far as springs
Old Jul 20, 2006 | 04:11 PM
I like it, it works well with 27" tires. it brings back alot of lost power although it does loose a little bit of topend.
Old Jul 20, 2006 | 10:14 PM
What will be the best for top end I plan on getting a stage II or Stage III clucth upgrade form vfjohn just not sure about swaping out springs and stuff never done any of this before
Old Jul 20, 2006 | 11:25 PM
  #15
if you have VForceJohn do you clutch dont do more than a stage 2 with a stock motor. as for colors, I dont know much going with his clutches. I'd guess maybe maroon primary almond secondary ?
Old Jul 21, 2006 | 01:04 AM
  #16
Why do you recommend no going more than a stage II clutch?? He recommended for me to go with a Stage III but I just was not sure about loosing my kebc by taking the fork out this is part of the Stage III mod
Old Jul 21, 2006 | 11:36 AM
  #17
stage 3 is a pretty extreme angle, so you need to have more than stock power to use it to its full potential it takes alot more power than stock to ride it up to the top of the sheaves. plus, hey stage 2 works great and is cheaper! lol
Old Jul 23, 2006 | 01:13 AM
  #18
I will be addinga vdi to the brute also
Old Jul 24, 2006 | 06:47 PM
  #19
just adding a VDI will not be enough for the stage 3 IMO... it will however be plenty to get all the use out of a stage 2 I may be wrong here though.
HYPERICHIE
Mar 5, 2010 02:28 PM
HYPERICHIE
Dec 14, 2009 03:17 PM
Hedgehog
Sep 27, 2009 07:44 PM
lnsmman58
Sep 1, 2009 04:31 PM
Instigater
Jul 15, 2007 05:30 AM
