blue smoke coming from 650i
was it pretty full of oil? sometimes a WOT run will blow a little oil from the crankcase vent into the airbox, and from there into the combution chamber. wheelies also do this. this is pretty common if this is what happened. i keep my 650i right at the full mark, but very seldom have the room for a WOT, and don't do wheelies anymore.
monty
monty
you should check your oil every day you ride it. sometimes the carbs stick and fill the cyllender (usually on a bumpy trailer ride). then if you try to start it it will hydro lock. this can damage stuff.
but if your oil is higher on the dipstick than before, make sure you smell it (for gas) and turn it over with the recoil starter once before starting.
monty
monty
Clean your air filter iclean mine with kerosene let it dry out then spray it with k&n air filte oil sounds weird but mine let out blue smoke after 200km i ws riding in a lot of dust a local mechanic told me this and has not smoked since i always take it out and clean it agter a log dusty rid now
