WHICH JET KIT DO I BUY
well i orderd one that come with instruction manual it says manual for ppl who have never jetted b4 (THATS ME [img]i/expressions/face-icon-small-smile.gif[/img]) here is the ad.........
KAWASAKI MOJAVE KSF250
scroll down to see all items available
Jet Kit
Kawasaki Mojave KSF250 jet kit $31.89
The jet kit comes with all the following brand new parts: precision machined main jets: 135, 138, 140, 142, 145, 148, 150, 152 and 4 stainless steel allen head bolts for the carb bowl. Instructions on jetting included.
sound good to you?
This kit is for modifications such as the following: aftermarket air filter, air box lid removed, modified air box, aftermarket slip-on exhaust or completely modified exhaust or cams.
Jet Kit
sound good to you?
#16
Yea the dynojet kit does come with instructions...thats what i have in mine. The down side of a dynojet kit is that the jets they give you are smaller and they only give you 1 main jet bigger then stock if you get the stage one kit.
Kenny
Kenny
#17
Hey, if your not sure about what size jet's you need you can always try dial-a-jet it's supposed to be easy to install and you can adjust what size it is externally. You should look into it. go to http://www.thunderproducts.com/dial_a_jet.htm
#19
the size of the dynojet kits are not auctually smaller, they just have difirent sizeing so th numbers are smaller then the stock jetts but the auctual size of the jet is not. I would go with the dynojet kit, it comes with decent instrucitons and comes with a tuning guide telling you what size jets to put in.......
