Moose module
I am looking into the moose module, because of price and all I really want is the low end power. Is there any problems with it on the 750 like the dyna has? Also, will it fit on my '02 P650, just in case I upgrade later?
I have used the Mooose module for awhile now and think that it is a pretty cheap mod for what it gives you. I do not know if it will fit your '06, but it will definitely go into your '02. That if it is the same module that I have.
The low end is right there and the rad fan does not run as much. Gas mileage may be a little more, but the benifits out weigh the downfalls.
Moose module is the easiest upgrade in the world. Took me 30 seconds to install and really has no drawbacks to speak of. It has absolutely zip zilch zero effect upon gas mileage or at speeds above 10mph, at least in my observations. Great upgrade for under a hundred.
Thanks guys. I have one on the way. I will try it out on both machines. I may end up using it on the p650, because I heard it makes it run better and cooler. Also I may have a lead on a VDI for the brute.
I have noticed that these items can be found used if you look around. People get sick of their quads, upgrade, or wreck em' and you can get screamin deals. I got my Moose from V2 for 50 bucks or so a few months back.
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
Elkaholic
Sep 6, 2015 02:44 PM
