Put up some pics of the lakota......
Old Sep 14, 2006 | 05:35 PM
Baja226sport's Avatar
Default Put up some pics of the lakota......
Where are the pics? My girlfriend rides a lakota and is in desperate need or new rear tires. Any suggestions? Also, simple bolt ons, air filter, jet kit, exhaust, do you really notice more power?
Old Sep 14, 2006 | 06:05 PM
mojo21's Avatar
These questions always appear on here "do you really feel that much more power?" ... the answer...yes you do. Any thing you do to the air box or pipe and motor you will feel. Its worth the money too.
Kenny
Old Sep 14, 2006 | 07:39 PM
holeshotz8436's Avatar
the only gain you will really feel will be a pipe but only a good one like the big gun......if you get the cobra or cheap dg system the only thing you will gain is alot of noise.......a jet kit does next to nothing and an aftermarket filter is pritty much the same as stock but will maby flow just a bit more......you will only feel substantial gains with a pipe, bigger carb or internal mods but every little bit does help......
Old Sep 14, 2006 | 07:46 PM
So a pipe and jetting would be the best bang for the buck???
Old Sep 14, 2006 | 08:05 PM
  #15
get a big gun pipe, twinair filter and rejet if nessary but dont waste money on the dynojet kit.....you can get bigger jetts at your dealer for 4 bucks each........so it will probally set ya back around 350 bucks
Old Sep 17, 2006 | 04:37 PM
  #16
Baseballroxmasox's Avatar
Originally posted by: BlazinBlu
Originally posted by: holeshotz8436
you should be fine with the 13tooth.....mine has a bit of engine work done to it which is the only reason im running a 14. i wouldnt worry about the tires they should take shape when you mount them
Ya holeshotz8436 they did mount up fine, looks good too, over them stock POS's. Thanks man for all your help.
Yeah RM did that to mine too.... they look fine and mounted perfect!
Old Sep 17, 2006 | 06:57 PM
  #17
rolsmojave3's Avatar
I like orange
Old Sep 17, 2006 | 07:04 PM
  #18
I like black.
Old Sep 17, 2006 | 07:35 PM
  #19
i like orange and black [img]i/expressions/face-icon-small-smile.gif[/img]
EIF
Apr 20, 2017 07:15 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Alex G.
Sep 19, 2015 06:34 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
MrTrashMan2U
Sep 9, 2015 11:44 AM
