2004 700 belt light ???
Old Oct 5, 2006 | 09:20 AM
MTHunter's Avatar
Default 2004 700 belt light ???
I have a 2004 P700 and the belt light came on.
The ATV drives like its brand new and I pulled the cover to look at the belt, it was fine.
So how do I shut off the light or do I just ride with it on?
Thanks!
Old Oct 5, 2006 | 09:55 AM
FASTFATBOY's Avatar
The belt light is a reminder installed by Kawi so you don't forget to check your belt. You can take it to the dealer to have them reset it, or go to dnsalis.com I think that's right. It's kissofdeath's web site and they have info on how to do it yourself. Or if your like me and are the lind of person who checks your belt deflection and checks it for frays and cracking when you change the oil just get a dyna or vdi cdi. Both will do away with the belt light, limp mode, and reverse limiter along with really wakeing up your engine.
Old Oct 7, 2006 | 07:20 AM
MTHunter's Avatar
I have a 2004 Arctic Cat with a 4 prong plug with a loop wire to reset the belt light for it.
I thought there woulld be a simple procedure for the Kawasaki 700P to reset it.
Please if anyone knows I would really apreaciate the post as I live in Montana and its an hour drive one way to the Kawasaki dealer.....
Thanks!
Old Oct 7, 2006 | 09:42 AM
firstkaw's Avatar
do what ffb said and go to atv.dnsalias.com and find the reset procedure or drive an hour[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 15, 2006 | 11:18 PM
MTHunter's Avatar
Thanks!
I went to that site and joined then I was able to get the tech info to reset the belt light.
By the way my belt was like new when I checked it w/2000 miles on the machine.
Thanks Again!
Old Nov 4, 2006 | 08:56 PM
saby73's Avatar
Only two ways the light will come on.
1 if the belt switch is activated (in the clutch cover)witch in that case you won't be able to ride more than 20 miles an hour(about that)and won't be able to ride 4x4 mode
2 the light will come on at about 100 hours of riding we saw from 90 to 110 hours of riding it depends.
on your 700 look just above the clutch cover you will see 2 big plugs 1 gray and 1 black unplug them and switch them turn your ignition switch on the belt light should flash fast then unplug the 2 prung plug and the light should flash slowly let it flash for more than 5 seconds then turn ignition switch off and replug everything to it's place if the belt light is still on after you put the ignition on then you must reset the switch in your belt cover.
COFatboy
May 2, 2020 12:06 AM
Cummins Driver
Sep 11, 2019 01:22 PM
bradco
Aug 21, 2015 08:11 PM
toonces
Jul 31, 2015 09:27 AM
