Brute force opportunity
Old Oct 9, 2006 | 11:18 AM
oldmanona400's Avatar
Default Brute force opportunity
I have an opportunity to buy an 05 Brute force 650 with only 20 hrs. on it. My concern is weather the newer models (06, 07) have new features worth paying for. Can anyone with in depth knowledge of the brute force help?
Old Oct 9, 2006 | 12:38 PM
alwaysride's Avatar
If it were i irs brute force i would say wait but its the solid axal brute which is just a prairie 650. They are very reliable so i would jump on the offer. Just remember to use low gear as much as possible. EX. mudding, climbing, pulling, etc. good luck
Old Oct 9, 2006 | 12:48 PM
The two concerns I have are the solid axal vs. independent. I ride alot of rough trails (rock). Also 650 vs. 750. I would prefer to stay in high gear except for long steep hills.
Old Oct 9, 2006 | 01:15 PM
FASTFATBOY's Avatar
The reason for using low is to help extend belt life. Both the 650 and 750 have more than ample hp and torque to pull up any grade you can ride up. You could use high but you would have to replace the belt more often than if you used low for the areas where you have a high torqe demand.
Old Oct 9, 2006 | 01:25 PM
I'm a clutch man. I don't want to come to a complete stop to change gears. How difficult is it to change the belt? and what about the solid axal vs. independent. I'm going from a 375 lb. bike to a 650 lb. bike. most of the trails I ride have lots of rocks and ruts.
Old Oct 9, 2006 | 01:38 PM
alwaysride's Avatar
the sra bikes are allot more sporty. Im sure youll be fine with the sra like i am. I ride allot of very rough terrain and im fine, But its your preference. Changing belts and so on is easy. Go over to nyrocatv.com and see for yourself under the teck tips section. The brute forces are the same as the prairies.
Old Oct 9, 2006 | 10:32 PM
RAMBLNMAN's Avatar
ride both types before you chose . irode both and i am glad i bought a independent based on the trails i ride on which is trails you have described
Old Oct 9, 2006 | 11:15 PM
SlyCulprit's Avatar
solid rear end is nice for rippin more like a sport quad, feels like it's stuck to the trail better, however I went with the 750 and had to get bigger wider tires as it felt a little tippy for my taste
Pgbama11
Jan 16, 2016 08:19 AM
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
ylomnstr
Sep 10, 2015 06:45 AM
ylomnstr
Sep 4, 2015 05:02 PM
