looking to buy kfx700 got ???.......
Old Oct 21, 2006 | 01:14 AM
sam's Avatar
sam
Default looking to buy kfx700 got ???.......
its used 2004...
.what should I be look for? funny noices from some where? tie rods , carbs give me any thing I want to buy but I want to know her weaknesses
he said all stock.50-75 hrs on it
can I mod the stock exhaust on these?
thanks
Old Oct 21, 2006 | 03:24 AM
Scooter86's Avatar
Knows Old ATV Questions!
You can definately put an aftermarket exhaust on it. I have seen single and dual silencer systems. It is basically the same motor as your Brute, and I believe they have some of the same issues with tie rods and other little things.
Old Oct 21, 2006 | 06:20 AM
justgo's Avatar
They do say the tie rods,,,but i still got the stock ones on and its doing ok,,,but other then that its just like and other quad,,some things just go out ,,got 300 hrs on mine and its still good.. ..Yes u can run,,single,,,or,,,duals....but u will have to rejet it and open your air box up,,,or the pipes are going to get realy hot,,
Old Oct 22, 2006 | 07:36 AM
ajd187's Avatar
Only issues are tie rods and ends, and possibly a sticking choke.
I actually never had any issues with my tie rods and ends until I struck a tree with the left side. So they are actually pretty decent. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 23, 2006 | 08:26 PM
CANAMMAN's Avatar
Swing arm bearings may be starting to rust out. While riding it about 1-3 MPH keep turning (swerving) right and left and listen for a clicking sound in swing arm area. Also push down and pull up on the rear grab bar and listen for the noise. Reason bearings don't last long is because moisture gets trapped in housing, cheap factory bearings, IMO they should have been manufactured with stainless steel.
Old Oct 24, 2006 | 01:19 PM
Hayashi's Avatar
If you don't mind the CVT and little hefty weight, get the 700. It's an awesome machine you can have lots of fun all day long.
Old Oct 26, 2006 | 02:18 PM
2lman's Avatar
I have an MBRP dual exhaust system I just took off, as well as JD Performance SS tie rods, with stock ends on them if you're interested.
MikeyBoyesq
Sep 7, 2015 10:44 PM
MALOCHALA
Sep 22, 2002 02:41 AM
Lurch77
Aug 7, 2002 08:00 PM
Kuntry
Feb 10, 2002 11:16 PM
flajimak
Oct 12, 2000 10:27 AM
