Break in period for Oil Change
Old Feb 13, 2007 | 03:02 PM
Uinthas's Avatar
Default Break in period for Oil Change
Rotella is Wally World Brand right?? why that brand & why 5w40 over 10w40?
Old Feb 13, 2007 | 05:29 PM
guzzler2's Avatar
You can get Amsoil from a number of dealers online. I think the ATV 0w40 and 10w40 range from $6-8 a quart depending on the dealer, so shop around.
Walmart has their own 100% synthetic in 5 & 10W30, I think the brand is Supertech. I looked into the manufacturer a while back...I think it is Havoline if I remember correctly. Has ratings similar to the regular Mobil 1. It doesn't have the Jaso MA rating, but I know a bunch of guys that have used it in Kawie V-twins with no problems. For $12 a 5qt jug, you can afford to change it a little more often if you want.
As far as filters, there are many choices. I use the Wix 51356 (same as Napa Gold 1356). Not sure if the BF 650 has the same amount of room as the 750, but this is a bigger filter. Also, a lot of guys on Kawieriders swear by the Purolator Pure One PL14610. I think both are about half the $$ of the Kawie filter and very good quality. You can find hours of reading on filters, but either of these will be great if you change your oil regularly.
I hope this helps.
Old Feb 13, 2007 | 07:40 PM
v2rider's Avatar
You can google in "amsoil dealers in my area" and go from there. I found a dealer 3 miles from my house that way!
Old Feb 13, 2007 | 07:57 PM
bombaman's Avatar
Rotella is made by shell and is a commercial diesel oil...because of this it has different additives then regular "car" oil sold by walmart and auto joints. 10-40 is not available in rotella synthetic only 5-40 as far as I know. There's quite a bit of information on this oil do a google search.
If you do want a pure synthetic go with amsoil or redline.
Old Feb 13, 2007 | 10:56 PM
  #15
Uinthas's Avatar
well I couldn't find any amsoil dealer so I just took the jar of vasoline & bought Mobile synthetic MX4 10w40...
next step is changing the rear & front diff's.. I assume mobile 424 is just as good as kawi's special lube right?
Old Feb 14, 2007 | 01:29 PM
  #16
Hayashi's Avatar
Mobil 424 is perfect for Kawi's REAR gear case which has wet brake plates.
Use engine oil 10W-40 (I use synth) for FRONT diff gear case - NO GEAR oil there.
Old Feb 14, 2007 | 03:21 PM
  #17
KJM's Avatar
KJM
In regards to synthetic oil, I've been told that once you go to synthetic you have to stay with synthetic. Is this true and what are the implications of putting in standard oil after running synthetic?
Old Feb 14, 2007 | 03:38 PM
  #18
Hayashi's Avatar
I switched back and forth betwen dino and synth oil (depending on my pocket condition), and noticed no obvious oil related problems on my vehicles (cars, bikes, quads, etc.). I am curious to know what scientific theory is behind for experiencing such problem. ???
Old Feb 14, 2007 | 03:58 PM
  #19
KJM's Avatar
KJM
My thoughts exactly. I got the advice from the Honda dealer. When asked why that is I got, "Is it what it is". In other words, he didn't have a clue.
Old Feb 14, 2007 | 07:55 PM
  #20
Uinthas's Avatar
Iv'e heard that crap quite a bit also, weather it's true I just simply dont know.. I wish there was a definative way to find out. Anyone know of national chains that carry mobile 424?
COFatboy
May 2, 2020 12:06 AM
atvcollector
Sep 8, 2015 05:11 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
Elkaholic
Sep 6, 2015 02:44 PM
donintennessee
Aug 19, 2015 02:22 PM
