break-in tips
Old Mar 26, 2007 | 11:58 PM
alltoos's Avatar
Default break-in tips
Drive it like you stole it. It has always worked for me on everything I have had to break in. Trust me. If you follow my advise. You will have one fast brute. If you baby it. You will end up with a baby.
Old Mar 27, 2007 | 12:49 AM
LTZGUY's Avatar
I do the same and had no problems. Every vehicle/atv I have purchased new or built an engine for I get it to operating temp and then pin it. Its either gonna go or blow.
Old Mar 27, 2007 | 11:49 AM
bigsled's Avatar
i would suggest getting in touch with mike for the anwser....
Old Mar 27, 2007 | 02:24 PM
LTZGUY's Avatar
Everyone will have their own opinion. There really is no right or wrong way. I bought a 07 civic SI a month ago and since day 1 I drive it like I stole it. Same thing with my atv when I bought it. When I took it apart to put the cam and piston it, there was virtually no wear. To each thier own.
Old Mar 27, 2007 | 03:12 PM
  #15
Frantic's Avatar
try easy riding for the first few hours, since its new, ya might wanna jump some small hills to soften the shocks. and hit the yard a little bit to get used to the handleing. just advice, check the shocks to see if they are bolted tight. mine was new off the floor, and after i rode if for a few hours the front right shock came apart, i guess because it came off an assembly line it didnt have that much custom work to it. just advice.
Old Mar 27, 2007 | 04:17 PM
  #16
jamakn's Avatar
Ride it like you stole it...
well, didnt want to admit it, but I to do that myself...and its worked for me.
I am however, likeing the synthic oil ideas...how is it in older Trucks too?
Old Mar 27, 2007 | 06:56 PM
  #17
v2rider's Avatar
Ride it hard! I have a 14yr old ATV, still runs like a top. My 6502 runs like a dream also. Both were broke in hard, and both have Amsoil 0-40. Have fun!
Old Mar 27, 2007 | 07:39 PM
  #18
87mac's Avatar
ride it like ya stoll it
Old Mar 27, 2007 | 08:24 PM
  #19
montyburns's Avatar
I heard you shouldn't use on older engines. I'm not an expert but I'm guessing that maybe it too viscuous? I put some in my F150 a few years back, it had about 80K miles and the rear seal began leaking about a week later. I use it my quads, and the 2 stroke sleds and boat as well. It's quite a bit more expensive but I figure those engines work quite hard so it can't hurt for the long haul. Just my 2cents.
Old Mar 27, 2007 | 09:29 PM
  #20
jamakn's Avatar
appreciate it, was thinking about my 2003 F-150. Usually Fords start to ooze a lil oil as they age (or used to). So far so good, but I do have 94K on it, and I drive it harder than I should. Put one of those K&N air systems on it two years ago and I still drive it like a kid with his 1st 4-bbl. muscle car...
