I Just Brought A 2004 P700.
Old Mar 27, 2007 | 09:22 PM
cajunkid's Avatar
Default I Just Brought A 2004 P700.
2004 320 hrs. on bike is this a good deal. What kind of problems will this bike give me. I paid $4000.oo need it for my deer lease to plow food plots. Bike looks real clean.
Old Mar 27, 2007 | 11:14 PM
cluby's Avatar
Get the clutchs cleaned and belt light rest, change all fluids, set valves, sycronize carbs, check to see if it's hade the knuckle update.
Other than that they are pretty good.
Old Mar 27, 2007 | 11:42 PM
Kawi650's Avatar
I would also upgrade the springs in the clutch to prevent high maintance bills down the road... I would also inspect the air filter, the out side can be clean but it's the inside that counts! Also if you are using it for plowing you might want to keep that rad clean from the inside. The blue spring could be a preference when plowing defentantly a black spring on it to is going to help. you got a good bike.
Old Mar 28, 2007 | 03:50 AM
cajunkid's Avatar
Thanks guys i will do!!!! The guy i brought it from said it had a re-call on the front end that was all fixed.
Old Mar 28, 2007 | 10:36 PM
bcbogger's Avatar
dont forget to check those swing arm bearings and motor mount bolts.Bearings need to be lubed at least once aseason or put in grease nipples and the motor mount bolts tend to come loose on a regular basis and try to kick it out of gear under load.
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
