brute overheating
Old Apr 25, 2007 | 02:28 PM
Supertone's Avatar
Default brute overheating
My 2006 BF 650I is overheating and using up alot of coolant.Fan is working and Brute does not smoke.Also i did have a lot of mud in my radiator.Could this be causing it to use so much coolant.
Old Apr 25, 2007 | 09:16 PM
gtchief's Avatar
Clogged radiator on those engines is a very bad thing. You have to be sure to clean it after every ride and make sure its not caked. I didnt think that would cause the coolant to go down, but I guess its possible. Definitely clean the radiator though.
Old Apr 26, 2007 | 12:11 AM
cluby's Avatar
possible that you took out your head gaskets.
Old Apr 26, 2007 | 09:12 AM
Supertone's Avatar
Think it might be water pump.Engine runs fine no smoke.Thanks for input.
Old Apr 26, 2007 | 04:42 PM
Hayashi's Avatar
Using up the coolant?
It has to go somewhere. It just can't disappear. It's either evaporating, overflowing, leaking, burning and smoking in the exhaust, mixing with engine oil or something. You need to find out where it is going.
Installing a coolant temp gauge is one of the best mods for water-cooled quads. I bought one for mere $10 from WalMart. The gauge face even lights up when headlight is turned on. Mine runs normally at around 190F when fully warmed up.
Old Apr 27, 2007 | 08:38 AM
booboobear's Avatar
thermostat may be sticking too
Old Apr 29, 2007 | 11:33 AM
RAMBLNMAN's Avatar
going out the overflow when it overheats due to the radiator bring plugged up, flush the radiator from the back side forward that should take care of it
Pgbama11
Jan 16, 2016 08:19 AM
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
ylomnstr
Sep 4, 2015 05:02 PM
