KFX 450 trouble...
Old Jul 18, 2007 | 12:02 PM
ryan32608's Avatar
Default KFX 450 trouble...
my 450 has 30 hrs on it and i was doing the scheduled maintenance. i unscrewed the smaller drain bolt (m6) to release the oil. when i went to screwed it back in it appeared to be stripped. the threads on the bolt are fine so i think it must be the casing on the engine block. f*ck. i took it to the dealer this morning and he is already talking about replacing the casing which will obviously require tearing down the engine, then replace, and rebuild- $$$$$.
a couple of observations/questions...
first, i'll be the first to admit that i have stripped my share of screws, nuts, bolts, etc. but i truly dont believe that i did this. it came out just fine but i noticed that the washer was bent and sheared so that filings were in the bolt threads. is it possible that this happened when they assembled it? when i put it back i did not force it and i stopped when i notice the symptoms.
second- cant they tap it? foreman said depends on how much metal is left inside. but cant they just use a larger bolt - there is a couple of inches of metal surrounding the hole- isnt that enough?
do i have any options? my buddy suggested getting a lawn mower oil plug to put in there. i dont know about that.
Old Jul 18, 2007 | 01:09 PM
FASTFATBOY's Avatar
Can it be helicoiled??
Old Jul 19, 2007 | 01:46 AM
Atvstevo1337's Avatar
thats a load of BS those bolts do strip the threads in the case very easy but it's as simple as helicoling it. done it to my 700 before
Old Jul 19, 2007 | 10:34 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
I've helicoiled the oil filter cap threads on my 400ex before, it's stronger than ever now.
Scrookie
Dec 14, 2010 04:02 PM
Master_Quack14
May 26, 2010 03:39 PM
ironcowboy
May 14, 2009 11:17 AM
endeduphere
Mar 24, 2006 01:10 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
