HELP PLEASE
Old Sep 7, 2007 | 11:23 PM
Fokus22's Avatar
Default HELP PLEASE
I borrowed a Kawaski brute force from a friend of mine and today while i was riding it i started getting backfire as i tried to accelerate. It also prevented me from going above 15 mph. Does anyone know what could have caused this to happen??? I did ride for about 3 hours with no problem and then blam outta no where. Someone please help!
Old Sep 9, 2007 | 12:27 AM
GR8Outdoorsman's Avatar
Default HELP PLEASE
Does it have Diff Lock on it? Some will limit the speed (similar to the way it limits the reverse speed) when Diff Lock is active. If there is an Override button, you can try pressing that and seeing if it accelerates better.
Old Sep 9, 2007 | 01:35 PM
blackknight's Avatar
Default HELP PLEASE
its gone into limp mod do the re set thingy
Old Sep 9, 2007 | 01:51 PM
Fokus22's Avatar
Default HELP PLEASE
yeah maybe i dunno what the deal is, i started it up yesterday and no problem all day. Extremely weird but thank you for your help.
Old Sep 9, 2007 | 01:52 PM
Fokus22's Avatar
Default HELP PLEASE
whats the reset thingy?
Old Sep 9, 2007 | 04:30 PM
quadzilla420's Avatar
Default HELP PLEASE
is the belt light on and if so, is it flashing or does it just stay on?
Old Sep 9, 2007 | 04:34 PM
Default HELP PLEASE
the "reset thingy" isa procedure you do in order to get the quad running past a certain rpm. You have to unplug 2 sets of wiring harnesses, mismatch them, and turn the ingition switch on and off in order to reset the "Limp Mode" (belt light). Pretty simple if you have the service manual
Old Sep 10, 2007 | 06:09 PM
Fokus22's Avatar
Default HELP PLEASE
i will try that if it happens again hasnt happened since but thank you to all who responded
Fokus22's Avatar
Default HELP PLEASE
