how to
Old Oct 8, 2007 | 12:43 PM
bad 750's Avatar
Default how to
hello can somebody tell me how to change the belt on the 750 brute force
Old Oct 8, 2007 | 04:44 PM
Hayashi's Avatar
Default how to
Remove the main center bolt that holding the drive converter onto the crankshaft end. Slide out the converter from the crank. Remove the belt and place a new one in. I've seen a guy (a really strong dude) removing the belt without taking the converter off from the crank with BARE hands - slowly rotating counterclockwise.
You rellay need a service manual if you want to do it right and avoid the frustration.
Old Oct 8, 2007 | 07:56 PM
alwaysride's Avatar
Default how to
I take my belt off with out getting the clutch puller toll. Just get a 27mm wrench and use it to help role the belt off then back on.
Old Oct 8, 2007 | 08:12 PM
bad 750's Avatar
Default how to
thanks but i got it off by hand i removed the centre bolt but could not get the clutch off the crank do you need a puller for this
Old Oct 9, 2007 | 03:50 PM
Hayashi's Avatar
Default how to
Yes, you can either buy a puller or make your own to slide the converter off the crank which is tapered - very tight fit.
