1994 bayou 400 4x4
Old Jan 15, 2008 | 08:56 AM
stumper's Avatar
Default 1994 bayou 400 4x4
I have torn my carb. apart and the vacum cup may have a pin hole in it. It doesn't rise whenever the engine is turning over. What is the purpose of this vacum cup? The engine will crank on choke and run but off choke the engine will idle for a long time. If I give it throttle the engine shuts off. Any help would be appreciated. Thanks, Stumper
Old Jan 15, 2008 | 09:43 PM
JustRandy's Avatar
Those CV carbs are junk. Much better off to get a non-cv carb and jet it yourself or find someone who can jet it for you. THe vacuum cup you are talking about actually opens the throttle as engine vacuum goes up. All you do when you give it gas is open a butterfly valve. A non-cv carb you control everything with your thumb. CV carbs are a pain and I refuse to work on them. Its cheaper in the long run to buy a simple carb that works and that anybody can fix if need be.
Google CV carbs and read up on them.
wendal
Oct 31, 2017 03:31 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
wendal
Sep 15, 2015 01:50 PM
rcappie4
Sep 9, 2015 07:04 PM
