How is the Mojave against other atv's?
Old Jan 25, 2008 | 07:30 PM
DX's Avatar
DX
Default How is the Mojave against other atv's?
I am wondering how the Mojave compares against the yamaha warrior, 300ex, and 400ex. I know it has liquid cooling, 11.1 cr, DOHC with 4 valves per cylinder and other things, but does this make it considerably faster than any of the atvs listed? Also, do you think it would keep up with a 400ex with a full Biggun exhaust if I put an exhaust and mild cams in the Mojave? Thanks.
Old Jan 27, 2008 | 01:21 AM
DX's Avatar
DX
Bump, I know somebody has an opinion on this.
Old Jan 27, 2008 | 09:03 AM
Scooter86's Avatar
Knows Old ATV Questions!
The Mojave should be right in the mix with the Warriors and 300EX's of the world. Depending on the trails and rider ability, you should be OK to hang with the 400EX too. You have to remember that you will have a power deficit to the bigger quads so if your buddies ride all out you will struggle to keep up. At reasonable speeds not so much. The Mojave has a good engine, and there is power to be had out of it, just don't expect to be taking a piped 400 in a drag or anything.
Old Jan 28, 2008 | 01:12 AM
JustRandy's Avatar
If you put a BIG carb on it,,, and do a full porting job,,, and a nice exhaust,,, and a nice set of cams...... You MIGHT be able to keep up with a stock 400 if you and your mojave are 100-150lbs less than the 400 and its rider.
Old Jan 28, 2008 | 06:42 PM
DX's Avatar
DX
Thanks for the responses. I am picking up my Mojave on Wednesday and I have friends who have a 400ex and a warrior so I was just curious. The warrior is stock but it hangs with the 400ex withought a problem so if it can do that, the mojave should be able to also without too many modifications. I am hoping to spend no more than $500 on upgrades.
Old Jan 31, 2008 | 08:12 PM
nevada's Avatar
your warrior(if stock) has less power then the mojave.
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
RidE
Oct 19, 1999 06:10 PM
dunc_n
Aug 26, 1999 09:32 PM
BlackHawk
Jul 31, 1999 01:31 AM
