lift kit install trouble
I'm installing a 2 inch lift from highlifter on a 06 750 brute. I took the top bolt out of the rear shock, the a-arms when down and the axles stoped the a-arms from going down further but had enough room to install the kit. The problem was in the front, i took the bottom shock bolt out and the a-arm went down 1/2 inch from the bottom shock bolt hole to the bottom mount hole. the pic in the kit is 1"1/8 inch from hole to hole. What is stopping the a-arms from going down further is the top ball joint. Anyone had this problem? How or what can be done. Or is this normal?
jrooker6
Apr 23, 2016 07:36 PM
mrtidy
Feb 3, 2016 05:00 PM
