Brute Force 650/AC
Old Feb 21, 2008 | 08:31 PM
25083's Avatar
Default Brute Force 650/AC
I have an AC 650 V2, IE BF 650. Do they make a block heater for this as mine starts so tough when cold? Any help would be appreciated. Thanks Guys.
Old Feb 22, 2008 | 08:33 AM
Hayashi's Avatar
Give a full choke and NO throttle at all when starting in cold weather. Still problem? Try new plugs. Mine starts just fine in freezing 10~20 F degrees.
Old Feb 22, 2008 | 05:25 PM
ATV24/7's Avatar
You may want to check the valves for clearence.
Old Mar 25, 2008 | 12:37 PM
25083's Avatar
Ok, egg on my face a little here. I tore down my carbs and did another complete cleaning. I checked the choke lever on the handlebar and it was letting the choke cable slip through, I replaced the $8 piece and my machine starts EVERY time, no matter how cold. This was my only Gripe on my AC and it is now resolved. I went on a nice 20 mile Powerline ride and never had a problem. Thanks for all the input on this guys, if the piece breaks again, a quick fix is not to replace the cheap plastic piece, you just steal a metal shifte lever off of a old 10 speed and use that, the cable ends are the same.
Pgbama11
Jan 16, 2016 08:19 AM
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
ylomnstr
Sep 10, 2015 06:45 AM
ylomnstr
Sep 4, 2015 05:02 PM
