kfx 700 slip on
Old Apr 18, 2008 | 07:22 PM
kfxrenegade's Avatar
Default kfx 700 slip on
i have a 08 kfx 700 and i put a hmf slip on my dealer told me, just to disconnect the batt, and the fuel injection would adjust itself, and as long as i wasnt racin or in the mountains all is well is this true.......
Old Apr 18, 2008 | 07:57 PM
wapiti1's Avatar
KFX 700 are not fuel injected. You will have to re-jet and open the air intake to reep the bennies of a new pipe. I can't believe the dealer would not know they where not injected. If you want all the skinny on KFX 700,see below.
http://www.kfx700.net/forum/
http://www.kawieriders.com/for...7879e63f8c24e8&act=idx
Old Apr 18, 2008 | 08:03 PM
with just the slip on am i doin any damage...its been 4 months and seems to run fine...i was told to unhook batt and i would adjust itself
Old Apr 19, 2008 | 03:07 AM
wapiti1's Avatar
Kawasaki KFX 700 do not come with fuel injection. It does not make sense why you would unhook and re-hook the battery to adjust for the new muffler. 700s are carburated and any adjustments made would have to be, new jetting, air mix readjusted, needle shim, and perhaps a pilot jet change. Simply adding a less restrictive muffler will not benifit you much at all with out upgrading your intake. example K&N air cleaner, air box mods ect... It was explained to me as "air in ,air out". When you modify air box and exhaust, you need to rejet accordingly. I would not attempt re-jetting if you are not familiar with the technique. I would recomend a shop do it, but not the shop that thinks these are fuel injected. I would recoment you visit the forums I recomended on my first post, there are folks there that know tons more about 700's than I do and are eager to help you with your quest to have a faster 700.
Old Apr 19, 2008 | 09:35 AM
QWODER's Avatar
I raced a guy in waynoka ok that just had a slip on and I think it hurt his performance.My 700 was bone stock and I beat him.But you might get a little better sound out of your 700.Like these guys said,the fuel injection is bull.
Old Apr 19, 2008 | 12:58 PM
but am i doin any damage to the quad....
Old Apr 19, 2008 | 03:14 PM
wapiti1's Avatar
I don't think so, You need to check you spark plug color to determine wether you are to lean or rich. If its running ok ,your more than likely ok. also monitor your radiator fan, if its comming on more frequently than before, it could be lean.
Old Apr 19, 2008 | 11:11 PM
it runs fine, ive run it with and without the pipe, what am i lookin for on the plug...
Old Apr 19, 2008 | 11:33 PM
wapiti1's Avatar
Your lookin for a light brown color. White too lean, Black and or wet too rich.
Old Apr 20, 2008 | 12:01 AM
k just checked it out, a little moist, and a little balck in color, but no worse then my kaw. b.f. 650, so whats that mean
