Axle Removal-2005 KFX 400
Alright guys, Im trying to remove my axle and need some more help please. Im trying to remove the 2 axle lock nuts on the left (sprocket) side of the axle so that I can "slide" it out of the right side. I FINALLY got the outside nut off, but the inside nut holding the sprocket holder will not budge at all. Is there some technique you guys use when removing stubbon nuts?
maybe heat it up slighty to get it to budge? I wouldn't recomend doing that, but i honestly have no idea what the strengths of these stock axles are.
Just lube that yotch up, let it sit, and start crankin on it!
