kawasaki 650 brute
the 2wd to 4wd indicators just keep flashing back and forth, its just the lights the drive it self still works fine, when you push the button to switch to 4wd it goes into 4wd but yet the indicators still keep switching back and forth, also when it does this when you go to stop, the bike will keep moving, its like the idol is up to hi or something. then sometime the cure is to just turn it off for few min and then it will work fine. Any ideas?
you need to take your seat off and underneath there is a black box with wires plugged into it, unplug all the wires from the box and plug back in. this will reset it. and the flashing should stop. sounds like your brute needs to go in for service when this happens. hope this helps
