Noise from under kfx700
I just bought an 04 kfx700 and it makes a clunk noise from the drive shaft area at slow speeds with the paddles on while on a hard surface. I was wondering if this was normal or is there somthing wrong with the drive shaft? Maby a u-joint or somthing, I dont know how the shaft drive works on it.
<div class="FTQUOTE"><begin quote>Originally posted by: Flameworks427
it makes a clunk noise from the drive shaft area at slow speeds with the paddles on while on a hard surface. </end quote></div>
Yes, that is normal in that situation. It is the backlash of transmission gears making the noise, load-no load-load, as the paddle tires are trying to roll on the hard surface.
jrooker6
Apr 23, 2016 07:36 PM
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
