Brute force engine rattling
Old Apr 6, 2009 | 03:19 PM
Mastakilla's Avatar
Default Brute force engine rattling
I started up my 06 brute force today only to hear a very obvious rattle. At first i thought i didnt tighten up some bolts when i fixed my winch. I got closer and it definately sounds as though its coming from engine. It has 1200 miles and original clutch. Any suggestions?
Old Apr 6, 2009 | 06:18 PM
tripld's Avatar
Default Plastic vibrating on front bumper??
I have an 05 Brute and mine has a sometimes loud vibration on high idle........it's the plastic on the front bumper.......could this be your rattle?
Old Apr 13, 2009 | 08:41 PM
OGGYDOGGY's Avatar
mine was the plow plate on the bottom that had loosened up .
Old Apr 14, 2009 | 08:46 PM
WPAbrams's Avatar
If its a tapping sort of sound it could be the compression release sticking
Old Apr 17, 2009 | 11:58 PM
750reasons's Avatar
I have '06 750 and I heard a rattle. It was the front engine mount. Bolt is under warranty, but the elongated ware in the engine block is not. Kawi will view these problems on a case-to-case basis.
The test is to put a bar under front of motor and see if there is any up and down movement. I had about a 1\2" play when I put pressure on bar.
Now there is no movement. When I change oil, I put power bar and socket on mount bolt and giver big time. Kawi will not warranty the next mount.
COFatboy
May 2, 2020 12:06 AM
velcro7279
Aug 24, 2015 01:15 PM
toonces
Aug 5, 2015 05:55 PM
Mikesohio
Jul 26, 2015 10:51 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
