carb leaking
Old Apr 21, 2009 | 04:37 AM
mewtwo's Avatar
Exclamation carb leaking
hi just bought a kawasaki 110 and the gas leaks out the overflow it will run but sputters cause the gas is too much could i get some ideas what it is and how to fix it thanks
Old Apr 22, 2009 | 02:45 AM
RPM's Avatar
RPM
Your carb float is probably bad. Pull the bowl off and see if the float has fuel in it.
Old Apr 22, 2009 | 03:10 AM
mewtwo's Avatar
ill check that thanks
Old Apr 26, 2009 | 08:33 AM
Kerbbirds's Avatar
Needle and seat that operates the float are bad.
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
