Brute 650 100hr belt light
Old Feb 7, 2010 | 10:21 AM
brianensor's Avatar
Question Brute 650 100hr belt light
Will the machine be put into a "limp" mode at the 100 hr mark when the belt check light comes on?
Old Feb 7, 2010 | 11:05 AM
DODGE57HEMI's Avatar
Mopar Man!
Yes! I ride with the 750's and this happens all the time. Very annoying!!!!! If you do your research there are directions on how to shut it of even while out on the trail.
Old Feb 7, 2010 | 11:46 AM
brianensor's Avatar
Yea I have a service manual and it leads you to think that it will go to "limp" but it does not come right out and say it. I'm going to copy the procedure and place it in a ziplock bag under the seat. I'm currently at 54hrs. Thanks for the info.
Old Feb 7, 2010 | 11:52 AM
Mopar Man!
Good thinking! I would even go on some of the Kawi forums as they can give you some good advice. I believe there are forums just for the Brut's themselves.
Old Feb 10, 2010 | 10:41 AM
dilogdp's Avatar
Default Belt light
My Prairie 360 just hit 100 hours and the light came on and it still rides fine. I spoke to the repair shop and he told me that it won't actually go into "limp mode" until the system actually detects a problem. When this does happen you can still "make it out" of most conditions.
Old Feb 10, 2010 | 11:28 AM
Mopar Man!
The 360 is a little different than the Brute 750's these engines have more power and the ones with EFI will cut power to save an a worn belt. Kawis are not known for having the best belt systems thus the 100hr checkup!
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
ylomnstr
Sep 4, 2015 05:02 PM
