spark plug, Carb issue
Old Feb 19, 2010 | 10:39 AM
smk8er's Avatar
Default spark plug, Carb issue
Ok so i have a 1996 Bayou KLF300 4x4. I keep fouling my spark plug. It is the correct type per the Clymer repair manual i have rebuilt the Carb and have set the needle per the Clymer Manual. But no matter what adjustments i make on the needle it still fouls. It has a dark black sout on it. It takes approximatly 2 days for it to get like this when it runs it runs fine and there is no power lose but when i go to start it after it sits it doesnt like to start unless i pull the plug and clean it or put in a new plug. Any ideas or suggestions?
Old Feb 21, 2010 | 04:57 PM
smk8er's Avatar
anyone??
Old Feb 22, 2010 | 11:44 AM
Hayashi's Avatar
Sounds like your choke is stuck at ON position at the carb and fouling the plug (even when choke is at OFF position). The choke on your Bayou is actually a fuel enrichening device not a butterfly valve that restrtricts the airflow. Clean out the choke plunger and make sure it really shuts off at the carb when the choke is at OFF position.
Old Feb 22, 2010 | 01:17 PM
smk8er's Avatar
Thanks you! Ill give that a try thanks for the response.
Old Feb 22, 2010 | 08:40 PM
Doctorturbo's Avatar
GOT BOOST!
If you are adjusting the needle only, that is JUST for idle fuel/air. It has nothing to do with fuel/ air mix when riding around.
It sounds like you need a main jet change to me.
How clean is the airfilter?
Old Feb 23, 2010 | 07:43 AM
Kerbbirds's Avatar
Have you lowered the clip on the main needle in the carb? Lowering the clip will raise the needle position which will lean it outsome , if its all the way up then you need a smaller main jet.
Old Feb 23, 2010 | 09:54 AM
Hayashi's Avatar
Don't change the original factory setting if the problem was not present from the beginning. Try to fix what went wrong.
Hankey Pankey
26
Oct 18, 2020 03:50 PM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
joshuafromny
Jun 22, 2015 05:30 PM
Joe04785
Jun 15, 2015 03:12 AM
Ask the Editor
Jun 3, 2015 04:16 PM
