Bayou 220 Problem
Old Feb 28, 2010 | 01:12 PM
1slowZ28's Avatar
Default Bayou 220 Problem
I just aquired a Bayou 220 that has been sitting for a while, it seems to be stuck in neutral, when I push down or pull up on the shift lever nothing happens, I adjusted the clutch but that didn't help, any ideas on what could be going on here?
Old Mar 15, 2010 | 06:35 PM
1slowZ28's Avatar
Ok guys I was told that something is messed up in the transmission and that I needed to do a complete tear down which is what I was afraid of. So is there anything I should know before I attempt this? like special tools or any tips or tricks? also if anyone has a guide or a diagram that would be great. Thanks in advance
Old Mar 16, 2010 | 07:06 AM
honkaw's Avatar
Yea I have a sugestion for you order a manual trust me it will be the best twenty bucks you ever spent
Old Mar 16, 2010 | 09:53 AM
Hayashi's Avatar
One of the causes could be the broken shift shaft spring P/N 921441235.
Old Mar 16, 2010 | 03:50 PM
1slowZ28's Avatar
that isnt something I can check without tearing into it is it?
Old Mar 17, 2010 | 02:08 AM
bayou rider18's Avatar
could be the shiftfork and either way u have 2 take off the side cases
Old Mar 17, 2010 | 07:32 AM
1slowZ28's Avatar
do I just have to take off the side case or do I actually have to split the crank case all together?
Old Mar 17, 2010 | 10:46 AM
smk8er's Avatar
do yourself a favor and buy a Clymer manual it will save you HUGE headaches and help you out...
Old Mar 17, 2010 | 11:38 AM
Hayashi's Avatar
Clymer, Hayden, Chilton are for shade mechanics and their print/photo resolution quality isn't that good at all. Get a real factory service manual if you want to get the job done right like pros.
Old Mar 17, 2010 | 11:54 PM
TexasRoadlawyer's Avatar
No Ruts, No Glory
I agree with Hayashi...the other manuals are a waste of time and money...the factory service manuals are what the pros use because it walks them through everything, gives them correct torque specs, special tool info, etc.
