kfx700 suspension
Old Jun 7, 2010 | 05:18 PM
himsa169's Avatar
Default kfx700 suspension
do kfx700's have gas or air in the rear shock n if its gas will it matter if i put some air in it to make it sit a little higher and bottom out less
Old Jun 7, 2010 | 08:00 PM
Doctorturbo's Avatar
GOT BOOST!
If you are bottoming out as bad as you say you are you need to put a new stiffer spring in it.
It's best to have a shop set up a new shock spring combo for your weight. The problem is, it's big $$$$$$$$$$$$$.
Old Jun 7, 2010 | 09:03 PM
himsa169's Avatar
i havent bottomed out in it but if i push it on jumps i will cuz i hit small jumps n i come real close but i dont have the funds to get a new shock or spring but on the thing im not sure the name of it but the cylinder that acts as a reserve for the shock it has a valve stem sticking out of it so i wanted to add some air cuz the rear kinda sags and if it is air wat is a good psi to fill it to or should i just fill it until it sits how high i want it
Old Jul 1, 2010 | 04:28 AM
adam B's Avatar
go with elka shocks they are the best
Old Jul 6, 2010 | 06:56 AM
dillan598's Avatar
ATV Rider Online helps you research the new 2009 Kawasaki KFX 700 suspension specifications before buying this Sport quad. Find out if this KFX700 ATV comes with a steering damper, adjustable rebound damping, and adjustable shock / spring pre-load, what is the suspension brand name and type, number of shock absorbers, and travel of the front forks and rear shocks. Simply choose from the options below to view the 2009 Kawasaki KFX 700 steering specs.
Hotel Italy
Apartments Italy
Robinhood
Dec 26, 2015 10:28 AM
bigred20653
Sep 19, 2015 02:11 PM
chewy78
Sep 8, 2015 10:37 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Mssarabug
Aug 10, 2015 12:56 PM
