mule 2510
Old Jul 21, 2010 | 02:55 PM
papa hogg scoot's Avatar
Loved
Community Favorite
You are very welcome.... maybe Mule will keep running perfect... Im here like others to help..... Ride Safe......
Old Jul 23, 2010 | 05:27 AM
williams8899's Avatar
I have a 2510 with the exact same issue as jamescr. Both inputs to the fuel pump relay are 12 volts with the key on, but the output (i.e., to the pump) is 6 volt, even with the engine running. Is the pump a 6 volt unit? There is no label on the pump with a rating.
Electronic Cigarette
E Cigarette
Old Jul 23, 2010 | 09:27 PM
Loved
Community Favorite
No it,s 12 volts
Old Aug 7, 2010 | 06:13 PM
Kiwinz's Avatar
Hi,
I have been working on mules for 10 years & it is common for this kind of fuel pump issue. It usally happens after a few years. The solution is to rewire the fuel pump power wire to a brown wire so the fuel pump goes when ever the key is turned on. The pump stops when it builds up to the shut off pressure. Once this is done you never have this problem again.
merryman
Jan 19, 2016 04:29 AM
ManuelCarrillo3
Where to Ride
Jul 27, 2015 07:53 PM
Aitch
Jul 21, 2015 09:40 PM
BaD660
Jul 31, 2002 01:11 AM
docfixit
Apr 25, 2000 10:32 PM
