09 Brute Force cam and head torque specs
Hi, had what appears to be a common issue - the atv died while going through water a little over the floor boards. I'm in process of doing a top end however have not been able to locate the torque specs for head bolts and cam bolts. Can anyone help? Would really like to get this completed. Any help would be greatly appreciated.
head bolts (m10) are 18 ft-lbs primary, 36 ft-lbs final, cylinder head bolts(m6) 87 in-lbs, rocker case bolts that are 2.2 inches long are 78 in-lbs, all other rocker case bolts are 87 in-lbs. i have the service manual as a pdf final, if u give me ur email i will send it to you.
1ArmBandit
55
Oct 14, 2015 09:03 PM
