How do you know...
Old Apr 17, 2011 | 12:20 AM
jg1559's Avatar
Default How do you know...
How do you know if your atv is overheating?
Old Apr 17, 2011 | 07:07 AM
mudslinger2's Avatar
I haven't been stuck since the last time!
Default Overheating
There should be an indicator light, the fan (hopefully) will try to run, and antifreeze will blow out of the overflow tube.
Old Apr 17, 2011 | 10:33 AM
jg1559's Avatar
Well none of those happened. I'm trying to figure out what happened yesterday. My atv lost power for about five minutes. It would go and slow down, go and slow down. So I drove it slow for a while, then it was back to normal. I thought maybe overheating.
Old Apr 18, 2011 | 12:29 PM
jg1559's Avatar
So the overheating indicator light finally went on yesterday while I was riding. Could it be due to the type of oil I used? Castrol GTX 10W-40.
Old Apr 18, 2011 | 01:11 PM
Hayashi's Avatar
Did the overheat happen right after you started using that engine oil?
Old Apr 18, 2011 | 04:23 PM
irinman2424's Avatar
how long did it sit with gas in it was the gas old wonder if the gas may have caused lack of power
Old Apr 18, 2011 | 06:03 PM
Hayashi's Avatar
Question
How would you explain the overheating indicator light coming on issue?
Old Apr 18, 2011 | 08:07 PM
jg1559's Avatar
It did happen after I started using the oil. But I believe I used the same viscosity of oil last summer, just a different brand.
Old Apr 18, 2011 | 08:08 PM
jg1559's Avatar
Gas tank, lines and the carb have all been cleaned out, and fresh gas put in.
Old Apr 18, 2011 | 09:01 PM
convicted21's Avatar
Subscribing... My King's fan runs ALL the time and Im wondering if theres an issue there? even though I haven't seen the light come on
warrior68man
Jun 25, 2004 10:27 PM
01ds650
Jun 13, 2004 10:17 PM
matykrak
Where to Ride
Jun 9, 2004 11:12 AM
warrior68man
Jun 8, 2004 06:31 PM
jcsact
Dec 29, 2002 12:33 PM
