Brute 750 timing
Old 10-05-2013 | 05:59 PM
Mr.SwampDonkey's Avatar
Default Brute 750 timing
I have a 07 brute 750. I got it half way running. The guy said it has a fully rebuklt motor but he was never able to get it running well. The 1st thing i did was check compression. 62 lbs each cylinder. I rebuilt the carbs. it s still doing the same thing. Sputters and backfires thru the carb when you give it gas. Idles ok. So im thinking it is a timing issue. Does anybody have advice on that. Is there a way to adjust it without pulling the heads?
Old 10-06-2013 | 11:25 AM
Zrock's Avatar
Super Quad Patrol
have you checked the carb for vacuum leaks? i had one doing the same and it had a leak between motor and carb i used a little rtv to seal and let it qure 24 hours
Old 10-06-2013 | 05:21 PM
No its possible but all the rubber boots looked good to me. I'll check it over to make sure though. Thanks
Old 10-13-2013 | 02:57 AM
TEXASBAGMAN's Avatar
62 LBS of compression is a in the low side.
1. Rebuilt motor
2.low compression. 62lbs both cylinders rebuild epic fail idk?
3.cam timing could be wrong valves opening to soon or late lowering compression.
4 cam timing could be 180 degrees out since guy who rebuilt it never got it to run!
excellent video on KAWASAKI cam timing on YOUTUBE. Its a factory video. If you can't find it let me know i have it..
5. I looked for video i cant find it. message e and can send it to you
Old 10-13-2013 | 02:59 AM
valve clearance should be intake 0.005 eshaust 0.008"
Old 10-14-2013 | 10:04 AM
1. Rebuilt motor
It's not an epic fail on the compression lol. The Brutes have an auto decompression cam which makes the compression between 55-65lbs normally
Old 10-15-2013 | 12:29 AM
66LBS TO BE EXACT. I didn't say your motor was an epic fail, i meant it would be unlikley that both cylinders would fail at the same time. I was only trying to help you as you where asking for some. Not sure if you want help or to pic apart advice and find some small detail to try an correct as the info was taken out of context and specifics where not given. So why does the compression release only drop it down to 66lbs? why not 56 or 46? Good luck with you BROKE FORCE!
Old 10-15-2013 | 11:42 AM
So 62lbs compression is way low compared to 66lbs?
Old 10-15-2013 | 11:46 AM
I did find a couple vaccum leaks. I havent had time to fix them but thank you for your advice. I will let you know how it runs soon as I get them fixed.
Old 10-16-2013 | 08:57 AM
I can see what the problem is with your BRUTE, YOU MADE IT VERY OBVIOUS!
